How to remove water pump bolts on my Z.
Postby Lip Ripper » Thu Jan 10, 2019 5:12 am
I know, it's my 240Z not a Comet but this transposes to any difficult bolt. In fact, my 5.0 had a water pump bolt twist off when I removed it. Thankfully it was flush with the block so I could weld a nut on and back it out. Anyway, I though I'd share it here.
https://youtu.be/dcEtg7CzDjI
Lip Ripper
Re: How to remove water pump bolts on my Z.
Postby Lou's Comet » Thu Jan 10, 2019 9:20 am
Pretty cool!
Postby popscomet » Thu Jan 10, 2019 11:49 am
Lip Ripper wrote:I know, it's my 240Z not a Comet but this transposes to any difficult bolt. In fact, my 5.0 had a water pump bolt twist off when I removed it. Thankfully it was flush with the block so I could weld a nut on and back it out. Anyway, I though I'd share it here.
that is a common thing it appears on a 5.0..same thing happened on GLENDA's mustang,,a pair of visecrips bailed me out..thanks the info,as always your videos are worth watching...thumbs up on that color on the falcon...by the way,on the 5.0 when I went back together,I used plenty of anti-seize not only on the threads but also on the shoulder of the bolt..cause that's where the bolt seize's at,,,seldom ever on the threads...thanks again STACEY !! pop
Postby Jims65cyclone » Thu Jan 10, 2019 9:10 pm
Great tip, Stacey! I shared the link with my son-in-law.
15x7x3.75BS TTII's all around
Postby redhotcomet » Fri Jan 11, 2019 8:20 am
Thanks for sharing!
redhotcomet
Postby tomb22 » Fri Jan 11, 2019 6:52 pm
Thanks Stacey awesome video
Return to Comet Lounge
Users browsing this forum: Baidu [Spider] and 1 guest
cron
