I think they have learned around here you don't eat the strawberries they are lethalpoboyjo65 wrote:so if you ever have a troublesome possum......
I just ordered some POR15 degreaser and metal prep, I found my bottle of Purple Power that I use to clean up grease and oil off the garage floor and used it on the block today, it worked pretty good, the POR degreaser is better stuff but don't get it on your skin because it degreases you as well, I wonder what it would do to my fat belly?Matty wrote:I just wired brushed mine sprayed with degreaser, and used paint prep. Working great thus far.
Another trick is on an aluminum intake, degreaser it and then go get etching mag wheel cleaner. Spray it on and scrub then rinse. Looks like it came right out of the box.
I was looking for mag wheel cleaner when I cleaned up the timing chain cover but couldn't find it (like a lot of stuff I have) I found the Mothers polish instead, that is why my cover came out so shiny really didn't want it that shiny but..oh well it doesn't show too much anyway.
I wish I had a bead blast cabinet so I could bead blast that stuff but I would probably end up ruining more stuff than cleaning it up.
Another question for anyone who might know, I think I am, more than likely, be modifying my oil pan into a rear sump because I can't seem to find a Fox body pan and pickup, which I don't think will be a big deal, but my question is about oil pickup tube, I am guessing I am going to have to find someone who can TIG weld to make me a new one, I only have my cheapie MIG. I might start looking for a long pickup to modify off of something else, I even wonder if something else will bolt right to the oil pump because most I have seen all look the same.
