Replacement Gauges
Replacement Gauges
May have asked this before and maybe it has been answered before so I might be lazy for not searching.
I have wanted to replace my dash gauges for years and considered mechanical gauges, you guys think electric ones are just as accurate now days?
The Volt and fuel would, of course, be electric, it would just be oil and temp that would be mechanical, if I went that route.
Re: Replacement Gauges
ARE you talking about a cluster of gauges under the dash?? or trying to get then installed in place of the orignals??.....we have electrical for oil and temp in GLENDA'S 56 ford,,seem to work just fine and has since back in the early 90's when we put them in,,,we even installed a temp gauge for the AT....
popscomet wrote:ARE you talking about a cluster of gauges under the dash??
I am going to try and build a new dash cluster, I have a second unit I was going to modify, I measured the faceplate (which is separated from the backplate) and it looks like 2 5/8" gauges would line right up in the back and hide their bezels.
Like these;
http://www.jegs.com/i/Auto-Meter/105/2315/10002/-1
I can get all 4 gauges that match and can choose between manual and electric on water temp and oil pressure.
BE easier to run a wire ,then a oil line or the bulb for the temp....jmo...I have all electrical for my cobra kit car,every one of them,,,,,wire is more simple to mess with and route thru the firewall
popscomet wrote:BE easier to run a wire ,then a oil line or the bulb for the temp....jmo...I have all electrical for my cobra kit car,every one of them,,,,,wire is more simple to mess with and route thru the firewall
I agree with Pop. the wires are easier. also no chance in the wire leaking oil on your carpet either like with a manual. the manual temp probe needs a bigger hole to go thru the firewall so an extra strike against it. as far as which is best I dont have a clue. I suppose either could fail.
Aussie Comet 1964
Post by Aussie Comet 1964 »
Hi Mike, this is what I did with my gauges, they are autometer 2 1/16" gauges, the oil is mechanical, they fit within the bezel, there is some cutting required with the metal backer, but the gauge mounts flat against the metal. John
1964 700 Mercury Truck
1964 Comet Ranchero
Aussie Comet 1964 wrote: there is some cutting required with the metal backer
I am ok with cutting the metal backer, this is a spare cluster I have anyway that I have actually done some repair work too, the biggest issue is finding the rest of it around here, I have the bezel part only in hands at the moment, I think I know where the rest is and will have to go digging sometime :roll:
Back in the day it seemed like performance folks always wanted the mechanical gauges, things may be different now days because maybe the electrics are more accurate.
Aussie Comet 1964
this is a back pic so you can see the modification
1964 Comet Ranchero
