The falcons in the early years didn't come with factory installed ac and it sounds like the comets may not have either. Most were dealer installed with the dealer moving the evap' as close to the dash as possible.
That comet in the post looks like the shifter is very close to hitting. But that's an easy fix with a hot knife just heat the bottom of the shift handle and bend slightly. That's what i did with mine and no harm done and you don't even see the blackened area from the heat as the boot hides it all.
To move the evap' forward i just cut and rewelded the mount brackets so they are further forward and just as solid and the evap just almost touches the heater box.
Air Conditioning - one piece at a time.
Re: Air Conditioning - one piece at a time.
That's a great car and cool story with documentation!poboyjo65 wrote:good news Pop! here is a 64 car that says the dealer installed ac with his 4 sp.. said the dealer moved the unit forward so the shifter would clear.which is good because I dont think you could move it to the side enough to clear without putting the passenger in pain.
http://topclassiccarsforsale.com/mercur ... speed.html
if you look at the pics it looks like it just barely clears. Nice car too!
that is a cool car !!boy that shifter is close....pop
It is hard to believe that is what color my Comet is supposed to bepopscomet wrote:that is a cool car !!boy that shifter is close....pop
