Which wire to the fuse block is the power wire?
Posted: Mon Jan 01, 2018 6:42 pm
by billybob
I am trying to replace the original fuse block with a stab in type fuse block. Can anyone tell me which wire to the original fuse block supplies 12 volt power to it?Should it be ignition on power? Thanks? Sorry. Its a 1965 Comet Caliente.
Re: Which wire to the fuse block is the power wire?
Posted: Mon Jan 01, 2018 8:52 pm
by tomb22
billybob wrote:I am trying to replace the original fuse block with a stab in type fuse block. Can anyone tell me which wire to the original fuse block supplies 12 volt power to it?Should it be ignition on power? Thanks? Sorry. Its a 1965 Comet Caliente.
There is a bigger black wire that comes from the battery side of the starting solenoid and goes to the amp meter and then splits off and feeds the fuse block, light switch and the yellow wire going to the ignition switch. The black with a green strip coming off of the stud on the ignition switch is the accessory feed.
Tom
Posted: Tue Jan 02, 2018 1:12 am
by billybob
Thanks very much for the help Tom22.
