Speedometer broken
Speedometer broken
Well on the first cruise in the Gal I noticed the odometer works but the speedo doesn't. Any idea's?
Re: Speedometer broken
Seems like I had one do that once, & the odometer still working, but my memory is fuzzy. it turned out to be the speedo cable wasn't pushed up in the speedo right,or all the way. I remember I was surprised that it started working after I fiddled with it,I thought for sure the speedo was broke. I cant remember what car it was other than I think it was a ford, & may have been a truck.
Many times, my speedo hasn't worked due to the cable not being pushed all the way in... in fact, just about every time I take the cluster out for some reason... but I've not really looked to see of the odometer is also not working.
I generally pull over when I notice no speedo, fiddle with the cable and it works again. As a rule, push the cable all the way into the speedo an let the trans end fall where it may.
But I would think if the speedo doesn't work, then the odo wouldn't work either. Aren't they driven the same way?
I'm trying to learn but I think the speedo is magnetic. It's hard to find any information on them.
OK...IIRC,the cable spins a magnet inside a steel drum connected to the needle which is spring loaded. The magnet doesn't actually touch the drum and the faster it spins,the more it grabs the drum,rotating it and the needle against the spring. Make any sense??? Anyway,IMO either the magnet fell off or the pivot point on the drum and needle has tightened up. I could have this turned around and the drum is on the cable and magnet on the needle but the problem would be the same.
On a side note,on it's maiden voyage,was backing my car out of the shop and happened to look at the speedo and it was spinning BACKWARDS! Back in the shop,tore it out and the drum and magnet were loaded with metal filings. Lesson learned...don't drill and grind under the dash with the speedo in the car.It was lucky I had a parts car with an extra speedo.
Good luck!
Good luck!
Well, I reached up and the collar was ever so slightly loose. Tightened maybe a 1/16 turn and boom baby, she works. And while cruising last night I turned the radio on so the light would fill the dash out. (radio wasn't working) Today I'm driving and thinkin what is that noise? I touched the volume on the radio and it works. Now the only thing I need to get working are the horns.
Hey, Lip, you need to start a business traveling around the country laying hands on guys sick rides and healing what's wrong with them.
Ha, behold the Miracle Worker.Lip Ripper wrote:Well, I reached up and the collar was ever so slightly loose. Tightened maybe a 1/16 turn and boom baby, she works. And while cruising last night I turned the radio on so the light would fill the dash out. (radio wasn't working) Today I'm driving and thinkin what is that noise? I touched the volume on the radio and it works. Now the only thing I need to get working are the horns.
