Road rash on your anti sway bar,, lol
Does anybody else have this problem,,
Re: Does anybody else have this problem,,
stop using it for a snow plow and that won't happen !! ….pop
Not yet anywaySASSY wrote:Road rash on your anti sway bar,, lol
it's coming...just give it timelavron wrote:Not yet anywaySASSY wrote:Road rash on your anti sway bar,, lol
I have scrubbed my belly bar a couple times when I had it wound up on a country road & hit a dip a little too fast. I just guessed when I made it,didnt have the motor in. I need to alter it ,raise it up a couple inches & it'll still be low enough to protect the oil pan. but the way it is now, I use the floor jack there & it will get the frontend really high!!
Been there done that tooJims65cyclone wrote:Better that than the oil pan.
http://www.cometcentral.com/forum/viewt ... ?f=1&t=966
I wanna know about that gas tank.
good eye lipripper!Lip Ripper wrote:I wanna know about that gas tank.
when I narrowed my framrails the tank wouldn't fit. the front of the tank pocket had to be narrowed too . it is narrowed 5'' ,the bottom half of the original tank & turned 180° & dropped a little in the rear, with the section that had the sending unit hole cut out & smoothed off. with a 15.5 gal cell fabbed to fit in it . full size top half of old tank for a cover.
fills from factory spout & unless you really know comets well it looks stock from above.
I used a piece of another tank top to make a lid to cover the rest of the tank pocket for a tool compartment.
on the new floor I bent the edge next to the tank to match the front pocket,so it looks right from below.
Superb.
