Page 187 of 227
Posted: Sun Mar 05, 2017 9:40 pm
loman wrote:I warmed the car up again today and then retorqued all the header bolts. Then I installed new valve cover gaskets. I glued them with weatherstrip adhesive to the covers first and reinstalled.
that's how I do it ,always have ....that yellow stringy 3m is hard to beat..........pop
Posted: Sun Mar 05, 2017 9:54 pm
Ole yeller is good for all kinds of things, I even use it around freeze plugs.
Posted: Mon Mar 06, 2017 12:30 pm
by anoNY42
1.) Switched out the oversized radiator overflow hose that was leaking at the bottom of my catch can. Now my car won't puke coolant unless it actually overheats!
2.) Measured my leaf springs and found I have what I believe are Mustang springs (22" front, 31" rear) rather than Comet springs (22" front, 33" rear). This would be why my shackles are pulled forward and sitting right on my frame rails.
3.) Had an odd moment where my T5 wouldn't go into gear with the engine idling. I shut the car off and it went into gear fine, then it was normal again once I restarted the car. The Internet says this could be my hydraulic clutch not disengaging fully, but it must only have been that one time because it hasn't happened since. Could the hydraulic line have gotten hot (I was tuning the engine and the line is close to the exhaust pipes) and caused that?
Posted: Wed Mar 08, 2017 9:30 pm
by loman
I changed oil on the truck and have now moved to the race car. I'm in the middle of draining oil on the race car now. Nothing like watching oil drain and sipping on a cold beer. Or maybe two. I also gapped a new set of plugs but I'll wait to put them in the day before I go to test n tune.
Posted: Wed Mar 08, 2017 10:02 pm
loman wrote:I changed oil on the truck and have now moved to the race car. I'm in the middle of draining oil on the race car now. Nothing like watching oil drain and sipping on a cold beer. Or maybe two. I also gapped a new set of plugs but I'll wait to put them in the day before I go to test n tune.
one or two? what ,did you buy a two pack?
come on man! some of us know you better than that!
Posted: Thu Mar 09, 2017 2:03 am
Posted: Sat Mar 11, 2017 6:29 pm
by Tims1965MercuryComet
Went to a car show in Clarkdale.
1957 Mercury
1958 Ranchero, chopped top, 1957 front clip and tail lights
Very nice 1957 wagon
Datsun 240Z it has a small block Ford
Posted: Sat Mar 11, 2017 6:47 pm
Luv the chopped chero!! the wagons are cool too! best looking motor I ever saw in a datsun!!!
Posted: Sat Mar 11, 2017 7:04 pm
x10 what john just said,,,,that's the only way to have a Datsun...they should have came from the factory like that
Posted: Sat Mar 11, 2017 10:57 pm
by loman
The Datsun is pretty cool, but I like the 2 door 57 Merc wagon the best. The lines, chrome, and dark color is beautiful.
Posted: Sat Mar 11, 2017 11:40 pm
by Rocket989
Posted: Sun Mar 12, 2017 12:24 am
Posted: Sun Mar 12, 2017 12:34 am
Is that merc a hardtop wagon?
Posted: Sun Mar 12, 2017 1:00 am
poboyjo65 wrote:Is that merc a hardtop wagon?
yes it is..........I know when new it had a Y block,wonder what's in it now ???
Posted: Sun Mar 12, 2017 9:42 am
by loman
I think that Merc would be a perfict fit for a healthy 351 Cleveland that can roast the tires.
