I have a 68 comet 289 hipo and i am restoring it very slowly...I have a vibration some where. I have replaced the harmonic dapner but still have vibration..Put new tranny and flex plate in too..Still Have vibration and got worse... Willing to try anything...Thankx toadskins
i had that issue when i did my 302. do you have the proper torque converter. the ballance of the torque converter may be off and that will cause a wicked vibration.
Drew Wanzer
"I love the smell of roasting tires in the morning"
did you find/fix the problem. fill us in so that if anyone has the same problem they will know where to start looking. new antidotes are always a good thing. every car is different and usually has a unique problem. you could help someone else or let us know if one of our fixes helped you.
Drew
Drew Wanzer
Just a thought, I don't know if you have a vibration while the car is in motion or not, but if it is, I knew a guy that had a street rod that had a nasty vibration.... he replaced everything and found out he had the pinon set at the wrong angle. I hope this helps. Good Luck!
