Is this a factory thing.
The Big Comets
Postby z28summit » Thu Dec 26, 2019 11:17 am
Doing the floor boards and under the bezel that holds the shifter we found this god awful hole cut in the same shape as the shifter bezel. This cannot be a factory cut no? I mean you would only need a small hole for the linkage to go through. Why go through the trouble to cut something like this, and it looks like it was done with dull tin snips.
With the shifter bezel
z28summit
Return to 66 - 69 Comets
cron
