slicks for stock rearend
- Aussie Comet 1964
Re: slicks for stock rearend
I do those top gear 7000rpm burnouts with the slicks !!!
1964 700 Mercury Truck
1964 Comet Ranchero
1964 Comet Ranchero
I love those old FE's,have a 63 390 with 63 406 heads in my 66 f100,,and a 3.50 rear gear with a 3spd on the columnshift.....it don't back up when you haul a load,pull a trailer,I can only dream about having one like you have,,nothing like having CU IN's..thanks, just always try to have that thing pointed in the right direction when you pull the trigger on it ... popfryedaddy wrote:it will do it POP that new 433 fe will burn those stock sized tires (4.11 gears} all threw ever gear its got.ton of tourque
sounds like ol POPs been there and done that.L.O.L im sure it will melt those slicks too, but its bound to do better with them.hey AUSSIE, that must be a pretty stout 302 in your mustang
fryedaddy
9.50's on a 6" rim? I don't think you'll get the footprint. I had mine on 7"s and that was pushing it.
And fairlaniac, I'm surprised that you didn't experience wheel spin. I see you're using radial's. Maybe that is better. I ran old fashion slick's with 8-9 lbs. of air.
i have some 8 inch aftermarket wheels i guess ill use. i was wanting to use my factory mags but thats ok it looks better with the wider chrome wheels on the back anyway.
fryedaddy
im sorry AUSSIE, i dont know what made me think your car was a mustang, i just go up a little while ago.still sleepy headed
fryedaddy
- Aussie Comet 1964
no worries fryedaddy, I was confused for a moment too, 302 is a stroker & it goes well, good fun to drive around.
6" rims are not ideal, but making special wheels would cost & alloys don`t have the right offset in the right style wheel I would run, but I usually ran about 18lb air which is a bit high but they hooked up good & worked for me, I ran 10.8s like that, now I run 255/60/15 et streets with a shorter diff so I can run 7s or 8 1/2" rims. JohnLip Ripper wrote:9.50's on a 6" rim? I don't think you'll get the footprint. I had mine on 7"s and that was pushing it.
1964 Comet Ranchero
1964 Comet Ranchero
i got them mounted today and put them on .i like the look they fit well,and i used the 8 inch rims with 4 and a half backspace. now heres my new question, what air pressure to use on the track and or on the street?
fryedaddy
i put 27 psi in those hoosier quick time pros,i took it out the highway and i noticed alot of bounce.i lowered it down to 20 psi the hopping and bouncing was gone but now the car seems to move around a little. im going to try 23-25 i hope it wont bounce or move around.[on the street that is],i wont get to take it to the track till later this summer. i have a few more things to do to get it ready
fryedaddy
