Page 5 of 5
Re: Wiper Motor Replacement
Posted: Sun Feb 13, 2022 9:41 am
by JimsHot66
Thanks for the info on the knobs, John. I never would have thought that there was more than one choice for wipers.
I still need to figure out why no 12 volts on the orange-white wire in the car after the last motor debacle. That'll be part of the process of cleaning up the wiring mess that is under the dash.
Posted: Sun Feb 13, 2022 1:14 pm
my motor got here yesterday ,so after reading Jims report I had to do some testing. hooked it up to a 2 sp switch first to test the motor. it's good. then I tested it on the intermittent switch,(I had already tested the switch on my 79 truck which is a plug & play). 2 sp motor works great & if I could leave well enough alone it would be a plug & play with no cutting or splicing of any wires.
so then I tested the comet footpump/swiper ,,works great with the intermittent switch & 2 sp motor! the weird thing is ; for instance when I have the intermittent set to swipe every 6 secs,but if I foot swipe it anytime before 6 secs, it resets the timer & waits another 6 secs before the next swipe. so if you have it set just right for how its raining & your running along & some big truck sprays you you can foot swipe it & not have to reset your intermittent.
I was determined to not give up my foot swiper,I like that feature better than intermittent. but having both will be nice.
Posted: Sun Feb 13, 2022 8:42 pm
by Jims65cyclone
I'm glad that foot swiper mod worked out on yours, John. Now, I want to include that in mine. Only problem is I don't have a swiper switch, and they're probably not that common to run across.
