Replace power brake booster
The Big Comets
Boxerhips
Post by Boxerhips »
I have looked in the usual places online (Advance, Autozone, Summit) and cant find one that will work.
I dont know that is it not inop, but I will say I took the small cap off the vac line that goes into the booster and it read "20" on my vacuum gauge.
Does 20 sound correct of a 390?
Re: Replace power brake booster
Yea 20 sounds about right to me. I dont think you can get an original booster. ''ABS PowerBrake'' is the name of a company that makes a thin one with a dual reservoir MC (front & back brakes) that is a popular upgrade. the dual reservoir is a lot safer than the factory single bowl MC. if you develop a leak you will still have some brakes on which ever front or back that isn't leaking. If you go to their site it is on or near page 80.
Boxerhips
Post by Boxerhips »
Are you saying I cant get one that is like the original?
I do understand the upgrade to a dual system, but I need to wait at this time.
So my option is remove the booster or replace what I have with an exact size unit. I have to imagine that there is at least one ford unit that will fit.
Boxerhips wrote:
Tue Mar 26, 2024 3:54 pm
maybe there is one for the 66 & later cars. Guess I was thinking mostly about the smaller earlier cars,but I'm still doubtful, dont remember hearing anyone on here getting one.
Might not work right if you remove the booster,I think the MC bore is different .
Maybe caveman or some body on here with a 66-67 can help ? ,,,, what year it is?
Boxerhips
Post by Boxerhips »
1966
I think Cardone will rebuild them for you, but you have to send it in and wait for it to come back: https://www.cardone.com/
Otherwise find a one in a junk yard (good or bad) as a core and send that one in for repair. It's not cheap, but I think John's correct. Mostly unavailable due to lack of cores. People keep throwing them out instead of saving the core.
I went with a dual MC bowl, got it from Dan over at Chockostang http://www.chockostangclassicmustang.com/
Give him a call, he’ll help you out.
