Radiator hose set
The Big Comets
Alex_
Radiator hose set
Post by Alex_ »
Hi all,
Me and my dad are swapping our 289 for a 302, but we noticed our radiator hoses have to be replaced (because they look ugly ;-) )
Are these hoses the same as a 66 289 mustang? They look Like the same thing to me, i found a number which i can order over here in the netherlands but i wanten to double check over here if you guys think theyll fit, Perhaps one of you have another OE number for me?
The ones i found are these: http://www.adamscc.nl/catalog/product_i ... pg8fhscp36
Our car is a 66 comet convertible.
Re: Radiator hose set
Just make sure the 302 water pump inlet (bottom hose) is on the same side as the 289 & if so then should take same hoses.
Comechero65
Post by Comechero65 »
A hose set for a 66 289 should fit. You may have to trim the upper hose some depending on the rad thickness would be all.
Alex_
Post by Alex_ »
Alright thanks!
