AJE K-member
straycat99
AJE K-member
Post by straycat99 »
Has anybody installed the AJE K-member on there Falcon Comet? Or have any info on the AJE install.
Thanks
Tim
StPro
Re: AJE K-member
Post by StPro »
I asked almost the same thing 44 views no replies. I am going to order one this week. I don't like that I it is hard to get answers from AJE. I think they are too worried about not selling a complete kit or someone might piece meal their kit. My plan is to order a kit and then I will re-engineer what I don't like. I am not going to use their struts. I want a more adjustable strut. I want A-arms with adjustable heim joints. I may have all or parts of their kit for sale. I need to see how the wheels set in the fenders and ground clearance with a dropped spindle. I may need a shorter A-arm to keep tires from rubbing on fenders. I will post more when the kit arrives.
Projects
65 Comet 421Stroker
70 Torino GT
straycat99
Re: AJE K-member
I have the same concerns as you. I emailed them and all they said is that the Mustang kit would work. I think that the track width, frame width, and suspension points(shock towers) would be different than a Mustang.
STPro please keep me informed on what you find out.
Tim
straycat99
Re: AJE K-member
Could not find Comet frame here is an Falcon
http://1bad6t.com/images/framerail/64-6 ... merail.jpg
And a 64 Mustang frame rail
StPro
Re: AJE K-member
Post by StPro »
Spoke with AJE today they say they can build me a Race kit with manual rack 2" dropped spindle and dual adjustable struts.
Projects
65 Comet 421Stroker
70 Torino GT
straycat99
Re: AJE K-member
Did they give you a price on the kit ? Would like to see one installed on a Comet or Falcon.
Tim
StPro
Re: AJE K-member
Post by StPro »
I did get a price on a Race kit. Part number MW6479R $2888.00
With double Adjustable Struts $3485.00
k-member,motor mounts, a arms, 79 fox 2"dropped spindles. c c plates, steering kit, springs and struts.
It will clear a 351 Rear sump pan and some race pans according to AJE
Projects
65 Comet 421Stroker
70 Torino GT
straycat99
Re: AJE K-member
Are you going to do it? Trim the towers?
Tim
StPro
Re: AJE K-member
Post by StPro »
I Was planning on cutting the shock towers as needed for headers. I also have no problem cutting up the lower control mounts and motor mount brackets. I would just drill out the spot welds so if I wanted to reinstall them I could. I just drill two I/8"holes in the parts to use as relocation holes.
Projects
65 Comet 421Stroker
70 Torino GT
StPro
Re: AJE K-member
Post by StPro »
I am getting anxious for the AJE kit to show up. I expected it to show already. I had some special things added that may have delayed it.
Projects
65 Comet 421Stroker
70 Torino GT
StPro
Re: AJE K-member
Post by StPro »
My K member showed today. What a great Birthday Present. Now I just need to get my knee healed so I can pull the motor out.
Projects
65 Comet 421Stroker
70 Torino GT
Re: AJE K-member
StPro wrote:My K member showed today. What a great Birthday Present. Now I just need to get my knee healed so I can pull the motor out.
Hey ! happy Birthday! Keep us up to date on the install :wink: !!!
StPro
Re: AJE K-member
Post by StPro »
Does anyone have an export brace under the engine on their comet?
Projects
65 Comet 421Stroker
70 Torino GT
Re: AJE K-member
StPro wrote:Does anyone have an export brace under the engine on their comet?
I have a home made one that I made from a mustang belly bar. falcon parts sells one. also ther is a new one that Joe help get developed,kinda pricey though;
https://www.pacificthunderperformance.c ... er-cm-1003
StPro
Re: AJE K-member
Post by StPro »
The reason I was asking is the K-member is located off the holes for the brace under the car so I was really just looking for a factory mounting hole location. So I guess I will look at reverse engineering it. I will use the spindle center line or clutch cross shaft to get front to rear location.
Projects
65 Comet 421Stroker
70 Torino GT
