under engine brace
under engine brace
Postby navychief » Mon Nov 13, 2017 3:04 pm
I just received the under engine brace that I ordered from Falcon Enterprises, same company that I got my curved monte carlo bar from. The brace looks pretty decent ,just needs slight clean up and paint,I paid $65.95 plus shipping for it . Any one using this bar ? and are the existing bolts long enough,or will I need to buy longer ones? thanks
navychief
Re: under engine brace
Postby Rocket989 » Mon Nov 13, 2017 3:17 pm
I used that same one..original bolts are plenty long enough! :D
Rocket989
Postby BJB » Wed Nov 15, 2017 3:13 pm
I take it that this engine brace would work with 6 cylinder engines also? We never got the V8 engine brace as our early Falcons were all 6 cylinder powered.
I have requested shipping costs to Australia. Probably will exceed purchase price.
Bruce
"I love a sunburnt country,
A land of sweeping plains,
Of ragged mountain ranges,
BJB
Postby navychief » Thu Nov 16, 2017 5:35 pm
Just finished installing my under engine brace from Falcon enterprises . The brace fit perfect, last week I installed the 1 1/8 dia front sway bar, Also installed a curved monte carlo bar ,from falcon enterprises ,The car handles great ,major improvement in handling, I am still thinking about installing the adjustable valve for the power steering to get more road feel.
navychief
Postby Rocket989 » Thu Nov 16, 2017 7:57 pm
BJB wrote:I take it that this engine brace would work with 6 cylinder engines also? We never got the V8 engine brace as our early Falcons were all 6 cylinder powered.
Bruce
Bruce - I thought the 6’s got an under engine brace and the V8 did not since they got torque boxes. I can grab some pics but the motor is in now so may not help much.
Rocket989
Postby lavron » Thu Nov 16, 2017 8:28 pm
Rocket989 wrote:Bruce - I thought the 6’s got an under engine brace and the V8 did not since they got torque boxes.
My 6 never had an under engine brace and it does have torque boxes (or used to have them before mother nature ate them) Not saying someone did not remove it before I got the car.
Postby Rocket989 » Thu Nov 16, 2017 9:03 pm
Huh - maybe all ‘63.5 or ‘64 & up had TB’s and dispensed with the brace. I did a little reading & the 6 brace looks different...V8 part might fit but can’t tell for sure.
Rocket989
Postby loman » Fri Nov 17, 2017 7:34 am
For those of you who have installed the brace, are you running headers? What kind of clearance issues do you have if any? After reading this thread, I'm wondering if this is something I should look into for my other car.
loman
Postby poboyjo65 » Fri Nov 17, 2017 12:03 pm
Loman headers are not a problem. they will come down way back behind the bar & steer linkage which is about under the motor mounts. I made one from a mustang bar. Added a jack pad that really comes in handy, fits in the cup of a floor jack & can literally pull the car around with the jack. it's just a slice of a big pipe welded to it. It's as handy as a pocket on a shirt.
347, 4sp, 9''......
JOHNO
Postby navychief » Fri Nov 17, 2017 5:37 pm
No clearance issues either, 65 caliente with headers and power steering
navychief
Postby Lou's Comet » Sun Nov 19, 2017 4:08 pm
poboyjo65 wrote:Loman headers are not a problem. they will come down way back behind the bar & steer linkage which is about under the motor mounts. I made one from a mustang bar. Added a jack pad that really comes in handy, fits in the cup of a floor jack & can literally pull the car around with the jack. it's just a slice of a big pipe welded to it. It's as handy as a pocket on a shirt.
Looks Great John.
Everything under there is so clean and new looking. Must be nice and easy to work on. The jack pad is a awesome idea!!
Postby poboyjo65 » Sun Nov 19, 2017 6:21 pm
Thanks Lou. I figure it's not so clean under there by now. I took this pic before june of 2016 when I drove it over to PF for the gathering, I was inspecting & greasing it. I need to raise the bar up a little. Best I remember I just guessed on height of it because I didn't have the motor in when I made it. I actually drug it once during a flogging session & hit a deep dip in the road right about the time I got out of it. :roll:
347, 4sp, 9''......
JOHNO
Return to Drivetrain
Users browsing this forum: Google [Bot] and 1 guest
