one wire alternator
one wire alternator
Postby navychief » Tue Aug 06, 2019 5:03 pm
I just completed install or A crate 302 from summit in my 65 caliente, blue print engine , runs great, I just bought A one wire alternator from summit, will my stock amp gage still work with this set up ?
navychief
Re: one wire alternator
Postby tomb22 » Tue Aug 06, 2019 7:56 pm
Where do you plan on landing the alternator wire? If you land it on the stock starter solenoid terminal that has the battery feed on, then yes your amp gauge will work like normal.
tom
Postby navychief » Wed Aug 07, 2019 3:38 am
Thanks Tom, that was what I was thinking , just run the alternator wire, eight gage to battery side of solenoid .
navychief
Postby tomb22 » Wed Aug 07, 2019 9:18 pm
How many amp alternator did you get? Eight gauge sounds small.
tom
Postby navychief » Thu Aug 08, 2019 3:33 am
A 100 amp , from summit
navychief
Postby tomb22 » Thu Aug 08, 2019 9:52 pm
navychief wrote:A 100 amp , from summit
100 amp calls for a #4 gauge wire. I doubt if your alternator will ever need to push out 100 amps. I wouldn't go less than a #6 gauge wire navychief.
tom
Postby navychief » Sat Aug 24, 2019 3:37 pm
Installed A one wire alternator in the comet , checked it out ,putting out 14.5 volts , amp gage on dash stays centered , put on headlights and needle goes to discharge ,checked voltage with lights on,still putting out 14.5 volts, why is gage showing discharge ?
navychief
Postby tomb22 » Wed Aug 28, 2019 7:58 pm
Sounds like your gauge is bad or possibly the wire on the back of dash is not snug in the amp meter holder. Could you post a picture of your gauge. Maybe that's what it should do. There is a big discharge when the lights are on.
tom
Return to Drivetrain
Users browsing this forum: No registered users and 4 guests
