squeaking upper a-arm..do I wrap dirty wd-40 soak gym socks?
CAComet1965
Post by CAComet1965 »
besides replacing the upper a-arm shaft with one with zerks, is there old school techniques to stop the squeaking.
I've heard of soaking socks in wd-40 and wrapping them around the shaft....
Does the mustang share the same a-arm shaft?
I believe the falcon does.'
Is there a difference between v8 and straight 6 assuming v8 is more beefier....
there's two listed on mac'sauto parts one is $26 and the other is $65....
Or do I just do the entire a-arm? If so, do I have to do both sides?
Do I have to get the car aligned?
Any recommendations? I live in So-Cal and rather pick one up.
Re: squeaking upper a-arm..do I wrap dirty wd-40 soak gym so
Post by comethead »
V8 and I6 same control arms.
65-66 Mustang use the same arms.
You could replace the shaft but it's kind of a pain. I tried it once and the threads where the end caps screw in were destroyed.
If there's a old Mustang vendor near you can get them there. I believe NAPA carries them too.
Also, I'd replace both. And the lowers while it's apart.
Yes the car will need an alignment when your done.
Good luck!
Comethead knows!. If you need a week or few to wrap your hands around the cash any of the mentioned ideas you said might work but wd40 anything you can squirt in there quicker to get you by to keep from it drivin you nuts. :D
loman
Post by loman »
My dad used to put Palmolive or Dawn dish detergent. I don't remember if it worked or not but he claimed it would work for a while once it oozed around everything .
almost any thing will work for awhile,,,,soap oil can wd40,,,anything slick even snot{ forget that last one,I was thinking out loud,,please dis re gard :shock: }}.....I shock my self self at times}} :shock: :wink: :D :lol: :lol: pop
Post by comethead »
If you throw a hand grenade into the engine compartment it'll fix EVERYTHING!
comethead wrote:If you throw a hand grenade into the engine compartment it'll fix EVERYTHING!
ONLY IF YOU PULL THE PIN 1ST,,,,OTHERWISE,,worst it can do is the fan hit it and tear up that big alumn rad,or your 5bladed flex fan :shock: :lol: :wink: :|
