65 stock leaf springs
Flintlock
Post by Flintlock »
I'm going to replace the stock leaf springs on my 65 with new ones of the same size/type. Is there any preferred brand or vendor I should be looking for? Are they all about the same?
Thanks
Flintlock
albert
Re: 65 stock leaf springs
Post by albert »
ESPO springs in Pennsylvania make a great product and are very helpful.
loman
Post by loman »
I bought mine from St Louis Spring years ago. IMO, the car sits to high. The car has never settled down at all. I would not buy from them again.
Rocket989
Post by Rocket989 »
McVeigh's...talk to Tom...they have a standard replacement and a spring intended for Ranchero's/ wagons that correct for our Comets that is a bit stiffer. I used the latter, but the lesser arch will cause the rear to sit lower (probably preferable by most):
OEM Comet Replacement Leafs
Industry Part# 66-237
Capacity: 710
Rate: 72
Arch: 10-3/4
Falcon Wagon/ Ranchero Leafs
Industry Part# 42-319
Capacity: 880
Rate: 120
Arch: 7-5/8"
