Filter in gearbox?
Filter in gearbox?
I have a mercomatic in my 64 caliente. The oil needs to be changed. I wonder if somebody knows if there is a filter inside the gearbox that needs to be changed and where in that case I can get a hold on one. Is the mercomatic the same gearbox as ford cruiseomatic?
Re: Filter in gearbox?
Mercomatic, Yes there is a filter. NOT replaceable, just clean the old one with brake cleaner or gas.
IF it's a C4... http://www.ebay.com/itm/NEW-Genuine-For ... 1341110446
Comet Bruce
Comet Bruce
Thanks i will do that when i change oil. Is the filter easy to spot when you dismanteled the oilpan?
If that trans is the same as the 2 speed used in falcons it would appear to have a filter which appears to bolt in so should be replacable.
- f2spexp.jpg (254.72 KiB) Viewed 2602 times
Replaceable but pretty much unobtainable...Comechero65 wrote:If that trans is the same as the 2 speed used in falcons it would appear to have a filter which appears to bolt in so should be replacable.
Bruce
Yes, right there.HarryK wrote:Thanks i will do that when i change oil. Is the filter easy to spot when you dismanteled the oilpan?
Bruce
So obviously replacements are not available. In that case the best you can do is just try to clean it and reinstall.bmmaurer wrote:Replaceable but pretty much unobtainable...Comechero65 wrote:If that trans is the same as the 2 speed used in falcons it would appear to have a filter which appears to bolt in so should be replacable.
Bruce
what ever you clean it with....blow it and let air dry as long as you feel safe ...jmo.....pop
Thanks for the help guys. How much oil do I need to buy before doing the oil change?
