63, ladder bars, coil overs.....
Re: 63, ladder bars, coil overs.....
Postby rjones35 » Sat Oct 21, 2017 6:02 am
Rocket989 wrote:Crites has some of that stuff already...minitub kits with relocating the rear frame rails, ladder bars, etc. At least might help with ideas.
Thanks! I've kinda looked at doing the relocation kit and mini tubs, but I think I want to do more. We'll see when it actually comes down to $$ though! Might rethink the big tires.
rjones35
Postby rjones35 » Sun Nov 19, 2017 7:51 pm
I'm still going round and round in my head, tub, mini tub, no tub, spring relocation, nothing at all and call it good....... I would like to put a bigger tire under it, just for the "look" really. How big of a tire can I fit under the 63 just by doing the spring relocation, like with Crites kit?
rjones35
Postby rjones35 » Wed Dec 06, 2017 8:47 am
Still going round and round.......might be back to the Crites kit idea. Seems like without narrowing the reareand it wouldn't help a whole lot because their is only so much room to go out? I guess just run a wheel with a lot of backspacing?
rjones35
Postby Rocket989 » Wed Dec 06, 2017 1:46 pm
I would narrow the rear...Crites may have some guidance if using their stuff.
'cause Johno says you gotta have a sig pic!! :)
Postby rjones35 » Wed Dec 06, 2017 3:05 pm
Narrowing and back half was my first thought, then I thought about cost.....
rjones35
Postby Rocket989 » Wed Dec 06, 2017 8:17 pm
I know an awesome local guy that can narrow the rear & you can use cut to fit axles, but yeah...all in all it’ll be a bit spendy!!!! :lol: :lol: :mrgreen:
Postby rjones35 » Thu Dec 07, 2017 8:57 am
Thanks, I've got a friend that can do the narrowing, its just the rest of the stuff, wheels/tires, third member, metal, etc, etc....... I'm still thinking on it.
rjones35
Postby rjones35 » Thu Mar 15, 2018 10:39 am
So I finally decided what I'm gonna do!! Nothing! Leave it as is and drive it. Actually I might put some lower gears and a posi in it, but that's it. Had it out a few times this year so far, it's loads of fun to drive!!
rjones35
Postby Rocket989 » Thu Mar 29, 2018 1:40 pm
Solid choice with it coming up on spring! If you do decide to get a limited slip diff, IIRC there's a guy in Columbia that sells ready to go pumpkins for the best price I've seen.
Off the cuff, I'd say 3.50's would be ideal with your T5. I've got 3.89's with the same trans and cruising at 80 is...a no... :lol:
ETA: Found it: https://columbiamo.craigslist.org/pts/d ... 26711.html
Postby rjones35 » Sat Apr 28, 2018 6:21 pm
Rocket989 wrote:Solid choice with it coming up on spring! If you do decide to get a limited slip diff, IIRC there's a guy in Columbia that sells ready to go pumpkins for the best price I've seen.
Sorry, haven't checked in a while!! I was thinking 4.11s, just because I don't drive on the highway much really, and I figure with the overdrive it would be okay. Maybe not? I checked that link, it was expired. Does he have 8" stuff too?
rjones35
Postby Rocket989 » Sat Apr 28, 2018 8:01 pm
He does do 8” chunks! I would go with the 3.80’s. I have 3.89’s & T5 with the same 3.35 1st gear. You might as well (and can easily do so) start off in 2nd! :lol: With 25.5” tires RPM’s are 25-2600 at 70mph.
Postby rjones35 » Sat Apr 28, 2018 9:47 pm
Rocket989 wrote:He does do 8” chunks! I would go with the 3.80’s. I have 3.89’s & T5 with the same 3.35 1st gear. You might as well (and can easily do so) start off in 2nd! :lol: With 25.5” tires RPM’s are 25-2600 at 70mph.
Nice! I'll have to keep an eye out for them.
I was just going to get a kit off Amazon - https://www.amazon.com/gp/aw/d/B00HS37L ... 603B&psc=1 -
and have a buddy set them up.
rjones35
Previous
Return to Drivetrain
cron
