Shifting too soon
65_Rat_Merc
Shifting too soon
Post by 65_Rat_Merc »
65 Comet, 200-6, C4 transmission. At full throttle, the trans is upshifting at about 3,200 rpm. How can I make it shift higher, at say 4,500 rpm???
Lip Ripper
Re: Shifting too soon
Post by Lip Ripper »
Kick down working?
65_Rat_Merc
Yes, the kickdown works.
Santa's Comet
Post by Santa's Comet »
You can get a little higher shift point by turning the screw inside the shift modulator.
Turning clockwise = higher
Later c4's you can change to different modulators.
As mentioned before the kick down needs to be set also.
Good luck!
NP Dave
Santa Dave is right. pull the vacuum line off & insert a small screwdriver , go about 4 turns at a time to start with.
