rear sway bar
Comechero65
Re: rear sway bar
Post by Comechero65 »
Rocket989 wrote:No doubt! Thanks for the pics...looks like you used the axle bumper mounting holes for the end links?
I fab'd my own brackets that are bolted to the frame to connect the end links to. Fab'd my own end links. It actually didn't take that long to grind down them down. Bench grinder for what i could reach and a hand grinder for the rest.
navychief
Re: rear sway bar
Post by navychief »
I went with the 1 1/8" dia sway bar front like you guys recommended the car handles great now ,no need for a rear bar .
Re: rear sway bar
navychief wrote:I went with the 1 1/8" dia sway bar front like you guys recommended the car handles great now ,no need for a rear bar .
That's good to hear! The big front one is like daylight to dark different than the stock 5/8'' bar with no ill effects.
