Upgrade your steering ( 65 V8 steering)
Re: Upgrade your steering ( 65 V8 steering)
Oh I thought it was that 3rd car that you're rebuilding.
Johno, actually I checked my other project car because I'm sure it is still original. It had the 65 steering that is shown in the first picture of this thread with the tie rods going to 3" inboard on the center link.
I dug out some power steering parts from a car I got rid of a while back. Are the v8 power steering parts and the v8 manual steer parts the same except the drag link? If that is the case I can buy a new manual drag link and swap center links with the power steering setup and I'm done.
Hard to say without seeing them,but they should be.but after seeing your other car,,, they could have been swapped out by now. Post up some pics. it will be good for this thread for future reference. but if they are 65 parts they should work,,, one of the tierod ends will have a big crook in it designed to clear the PS,but should still work right.
Looks like the same issue I had. My 65 Falcon was hit in the passenger front way back when, which is probably when the Frankenstein cobbling started from a 64 donor. My core support has a few 64 stampings and was patched, 6 cyl manual steering with 63-64 v8 spindles. I had to go find everything LOL!
Dan
Dan
Johno,poboyjo65 wrote:Hard to say without seeing them,but they should be.but after seeing your other car,,, they could have been swapped out by now. Post up some pics. it will be good for this thread for future reference. but if they are 65 parts they should work,,, one of the tierod ends will have a big crook in it designed to clear the PS,but should still work right.
Here are the pics.
65 Mustang V8 manual steering
65 Comet V8 power steering
65 Comet V8 manual steer (car I am currently working on)
After talking to John at Opentracker, I've ordered a 65 Comet manual steering drag link and I am going to use the mustang steering components. His thought and I agree with him is that I have 6cyl steering parts somehow connected to V8 spindles. I did some measuring and I'll list what I found in another post.
I reposted the picture and changed the label on the last one.
Johno, I originally labeled it that way with the question mark because I originally believed it to be that way until I started digging into my messed up steering situation.
- thumbnail_IMG_1995.jpg (40.5 KiB) Viewed 6931 times
- thumbnail_IMG_1999.jpg (42.18 KiB) Viewed 6931 times
Well I had to downloaded so I could zoom in to see it but you have the lower one labeled wrong, it is 6 cylinder stuff. the 65 comet manual v8 links will be just like the stangs but the centerlink is a different length.
Here is some info about the parts in the pictures I posted.
Spindle part #, i wire wheeled the spindle but it was still hard to read the number
Mustang C6DA 3107B
Comet PS C(5or6)DA 3108B
Comet MS C5DA 3108B
I measured the hole where the tie rod connects to the spindle and all 3 spindles were the same. The small hole (top of taper) measured about.430 and the big side of the hole measured about .485 or so. That makes me assume that all 3 sets of spindles are in fact V8.
All 3 tapers measured the same on the tie rods even though the one on the Comet MS setup has a smaller stud than the other 2.
Mustang C6DA 3107B
Comet MS C5DA 3108B
It probably is V8 links from 63-64. you cant tell about the spindle hole size in the pics . Reason I thought it was 6cyl parts is they were in a 65. 65 6cyl parts look just like 63-64 V8 parts. I just thought having a pic of 65 ps links would be good & you did a nice job of laying the other links in the pic for comparison.
Has anyone compared the tierod location between the 64 and 65 spindle?
I don't have a 65 to compare to.
These spindles are steel and I have already modified mine so wondering if I could cut the tierod mount off and put it where the 65 is?
Fred look on pg 1 of this thread. some comparison pics on there. the earlier ones were just straight & 65's drop down.
there is a bump steer kit that drops it down,so the tierod linkage is about the same level as 65's. you might check into that.
I’m pretty sure the C3xx V8 spindles match up very closely with the C5xx V8 part. The tie rod hole is smaller (IIRC). I’ve got a pic somewhere that compares the two. A lot of folks say they’re different, some (like Denis @ CSRP) say they’re fine. I used new spindles but my old ones probably would have worked fine.
ETA - found pic:
ETA - found pic:
I now own a pair of 65 spindles.
Only difference I can see 1) the 65 looks have a smaller hole to mount the tierod
2)the 65 tierod mount hole is about 1.125 inches lower than the 64 but on the same centerline.
Think I will further modify my 64 spindles to replicate the 65s.
Upon a PM discussion with Johno I will probably shorten the distance from the ball joint to the tierod to quicken the steering as well.
FYI for those going original Autokrafters has a new quick ratio gearbox advertised part # c4dz3504A currently $499
Bit pricey but if you need it you need it
Excellant info..... you just answered a bunch of questions I had ! Thank you... ....Ron
