Spare Tire
Posted: Tue Jul 24, 2018 9:08 am
Can I use a trailer wheel for a spare? I have the new wheel and one new tire that is just a size larger than my front tires (same brand as what I put on the car), I thought it would be a good in-between size front and back.
Of course I don't have to use the trailer wheel, I just have it already and would have to source a 15" wheel because the Jeep wheels are really wide with an odd offset. I could steal the spare out the Jeep, I don't remember if it is a temporary spare which I guess would work ok as well.
Re: Spare Tire
Posted: Tue Jul 24, 2018 10:15 am
Re: Spare Tire
Posted: Tue Jul 24, 2018 10:34 pm
by Jims65cyclone
I see no reason you couldn't use the trailer wheel, assuming it's a 5 x 4.5" bolt pattern. It probably doesn't have much of an offset, but is probably only 5" or 5.5" wide, so the tire will probably have a fairly narrow profile, so it shouldn't rub. Give it shot and see.
Re: Spare Tire
Posted: Thu Jul 26, 2018 10:14 am
by 62Cometman
As im sure you know most trailer tires do not have as high of rating for speed as a standard passenger vehicle tire would, and depending on the style may not have as heavy a load rating so just be sure if you bought a premounted system that it will work on your car without having to worry about the weight and or speed of your vehicle
Re: Spare Tire
Posted: Thu Jul 26, 2018 10:35 am
by Lip Ripper
It explicitly says not to on the tires.
Re: Spare Tire
Posted: Thu Jul 26, 2018 10:45 am
by bigdan
First, yes, they'll fit, which is a plus. On the other hand, I'd check the rating. My car hauler and boat both run the same bolt pattern and wheel, so when I put new tires on everything, I went with the 8 ply, and I carry a spare of the same size. All 3 axles are 3500#, which is way more than one of our cars. Both the car hauler and boat pull at 75 no issues, with weight, so for a temp "you get me home" fix I would think it's ok.
Dan
Re: Spare Tire
Posted: Thu Jul 26, 2018 3:29 pm
Lip Ripper wrote:It explicitly says not to on the tires.
The tire is a car tire, it is just like what I have mounted on the Comet wheels but is a size larger than the front tires.
bigdan wrote:so for a temp "you get me home" fix I would think it's ok.
Yes not a permanent wheel and tire combo, I may come up with a wheel before the time comes, I will just need to make sure it will fit over the disc brakes and have the correct offset, of course I already know the trailer wheel will fit on the back
Re: Spare Tire
Posted: Thu Jul 26, 2018 3:54 pm
by Lip Ripper
My Falcon trunk is so small that I think I'm just going to carry a small 12v compressor, tire plugs and a can of Slime.
Re: Spare Tire
Posted: Thu Jul 26, 2018 5:19 pm
Lip Ripper wrote:My Falcon trunk is so small that I think I'm just going to carry a small 12v compressor, tire plugs and a can of Slime.
Well I will already have onboard air, I guess I am thinking about a destroyed tire scenario
John is probably right, I am way ahead of myself
wishful thinking I guess.
