Ride height
rickyv
Ride height
Post by rickyv »
I have a 1962 comet and i was wanting to raise the whole car up a little. Didn't know if someone had already done it and if so how'd you go about it? anything helps thanks
Re: Ride height
Just putting new leafs on back & coil springs on front will bring it up a lot! if that isn't enough You could add spacers on top of the coils, air shocks on rear.
Re: Ride height
A least expensive, least work solution may be air shocks on rear and twist-in spacers on front coils. The twist-in spacers are fairly easy to install, but are subject to coming out if you hit a pot hole, and can change the alignment.
