Power steering
rhtopdown
Power steering
Post by rhtopdown »
How do I change my 64 comet to power steering are there any new kits available
Re: Power steering
Think I was reading that Flaming River(think that is the name?)
Does a kit with in box power, rag joint and will make you the custom length shaft.
Would make a nice clean install. Think Johno has this in his 65.
Re: Power steering
Mine is from borgeson. now they have a 14:1 box which would be even better than the 16:1 that I got. with some fabrication I was able to use my factory column but it's easier with an aftermarket column. they do have a kit, made for a mustang but with modifications will work on comets/falcons. A rag joint will need more fab work to build a cover for it, since it lands dead in the firewall. but some have just used a coupling that will fit inside the column tube, & at least one guy that I know of has kept his column shift (auto) with some mods.
you can build an electric PS from junkyard parts if you feel comfortable cutting & welding on steering shafts. but it can be done for under 100 bucks. Fred (SASSY) can tell you all about that if your interested,he did his.
