Brake Question?
Brake Question?
I have drum brakes on my 64 everything new also single master cylinder still hard to stop almost have to stand on them. I had another 64 a couple years ago same set up but put dual master cylinder on it. It seems to stop a lot better. Do you think change to dual would help? Need your input. Thanks
Re: Brake Question?
It won't hurt, I blew my wheel cylinders twice on my Comet and the first time was pretty exciting not having brakes, second time not so badrhtopdown wrote:Do you think change to dual would help?
But you may have an issue with the soft lines being collapsed unless you changed them as well, they may look ok on the outside but are not on the inside, I think that is what was wrong with my Comet when I parked it 20 years ago, I didn't have the internet or this forum to help me learn that.
Re: Brake Question?
the car was a 3 on tree at one time someone change to c4 and put shifter in floor. clutch pedal still there but up against firewall. could this effect how hard I have to push the brakes to stop
Re: Brake Question?
Shouldn't, they are basically unrelated unless the pivot pin is worn out I can't see how it would.rhtopdown wrote:clutch pedal still there but up against firewall. could this effect how hard I have to push the brakes to stop
