64 comet master cylinder
rhtopdown
Post by rhtopdown »
has anyone change from single master cylinder to dual master cylinder and proportion valve on 64 comet. IF so which master cylinder and proportion valve did you use. thanks
4 wheel drum
Re: 64 comet master cylinder
Just a few threads down in this area is what I did on mine.
http://www.cometcentral.com/forum/viewt ... 13&t=15288
rhtopdown
Post by rhtopdown »
these post are about disc brakes, I want to change from single to dual MC for my all drum brake 64 comet
rhtopdown wrote:these post are about disc brakes, I want to change from single to dual MC for my all drum brake 64 comet
contact ABS power brake & tell them what you have & what you want ;
http://www.abspowerbrake.com/
I'm sure other brake companies could help too.
You could either go 67 Mustang
https://www.rockauto.com/en/catalog/for ... inder,1836
Or 72 Maverick
You won’t need a proportioning valve. But you will need a 10lb residual pressure valve to the rear brakes.
Opps :oops: , missed the drum brakes part. I did that as well before going to discs, ordered one for a 70 Maverick all drum car.
rhtopdown
Post by rhtopdown »
trying to change from single MC to dual. got Dual MC for 67 mustang all drum brake. the two outlets on it are 7/16. the steel brake lines going to new MC are1/8 Also replacing the two rubber brake hoses on front. where they connect with steel line is 7/16 but connect to wheel cylinder they are 3/8 Help Please and Thanks what does it sound like to you.
You can get reducers for fittings at the MC . maybe you got the wrong hoses? or maybe I'm misunderstanding you. :?
rhtopdown
Post by rhtopdown »
Do they make a dual master cylinder with 7/16 x24 thread size that will fit my 64 v8 comet. If so where. I can not find it.Thanks for any help with this.
rhtopdown
Post by rhtopdown »
O K got adapter fittings for the new dual Master Cylinder, replaced rubber brake hoses they were 3/8 on one end and 7/16 on the other did not know why but my local Ford man said it came off a 68 Comet or ordered it and it fit perfect. So it fixed it. Thanks for every ones help
