Light Surface Rust on Flywheel
I have a spot of light surface rust on my new flywheel about the size of my hand, should I clean it off or just not worry about it?
If I clean it what should I use?
Re: Light Surface Rust on Flywheel
It wont last long with all the slipping clutch problems Ive read about on the site! :mrgreen:
I would probably just lightly sand it.
0000 steel wool. 4 ought steel wool is great for that ,to clean glass,rusty chrome,,,you'd be surprised at what it will do for it. it wont take out pits but it'll make it look a lot better. 0000 wont scratch.
Thu May 07, 2020 2:40 pm
No pits mostly just red colored in one spot.
lavron wrote:
Thu May 07, 2020 5:48 pm
In that quote I was referring to using it on rusty chrome . Things like the inside windshield trim on hardtops & bumpers it does really great. but on your flywheel it will take off the rust without affecting the grind swirls.
