STEERING ISSUES
fryedaddy
STEERING ISSUES
Post by fryedaddy »
i went to the grocery store in my comet the other day and on the way home my car was moving around a lot. it kinda scared me a little. when i got home i jacked up the front and checked it out.the pass side wheel was tight and felt ok,but the driver side was different,i cant wiggle the wheel up and down but side to side it is loose.it has play in it.you can wiggle it a inch or more without the steering wheel moving.im no front end man.would this be a tie rod or something.i guess i need to get under the car while someone wiggles the wheel so i can see whats moving.any ideas?
fryedaddy
Re: STEERING ISSUES
You just answered your own question. Yea get a buddy & see where the slop is.
Re: STEERING ISSUES
I use to wiggle in front of my wife an sometimes she would get frisky,,,,, now she says,,,,, get out of my way!! :lol:
Re: STEERING ISSUES
I'd pop the spindle nut off first and check the wheel bearing.
Don't need help w/ that one.
Fred, you brute! :lol: :lol: :lol:
Re: STEERING ISSUES
fryedaddy wrote:
Sat Jan 08, 2022 2:01 pm
Probably a tie rod on drivers side, inner or outer. If it was idler or pitman you would feel some play on other side too. If it was ball joints or bearings you would have play up and down.
Re: STEERING ISSUES
Lou's Comet wrote:
Sat Jan 08, 2022 9:15 pm
I agree exactly on all points.
