Final installation of front steering and Suspension
JCBond
Post by JCBond »
Hi
I have everything installed on the front suspension and steering. I have a 1963 comet V8 with manual steering. Everything was replaced except the center-link, sway bar, spindles, and spring perch. Does any one know what should be tightened in the air and what should be tightened with the weight of the car?
Thanks
Re: Final installation of front steering and Suspension
The lower control arms & end links of the swaybar. also tires need to be straight ahead to tighten up the idler arm bushing.if I have forgot anything someone will remember.
