Hi
I have everything installed on the front suspension and steering. I have a 1963 comet V8 with manual steering. Everything was replaced except the center-link, sway bar, spindles, and spring perch. Does any one know what should be tightened in the air and what should be tightened with the weight of the car?
Thanks
Final installation of front steering and Suspension
Re: Final installation of front steering and Suspension
The lower control arms & end links of the swaybar. also tires need to be straight ahead to tighten up the idler arm bushing.if I have forgot anything someone will remember.
