Limited slip diff
Limited slip diff
Hey guys does anyone know what limited slip rear ends will work on these cars? Specifically my 67.
1967 Comet 202. 289. Work in Progress
Re: Limited slip diff
Good used 8" Trac-Lock units are unobtanium and probably shot if you did find one. Have a 'L' stamped with the ring gear ratio on the carrier tag.
Yukon & Detroit both sell new units that will set you back around $500.
This is what I purchased for our 66 8”
https://www.amazon.com/Ford-Trac-Lock-P ... C67&sr=8-7
might know of an 8 inch Trac Loc with new clutches.If interested,let me know and I'll find out if the guy still has it.
I have a reproduction 8” Ford Traction Loc in the Comet and an Eaton TrueTrac diff in the Falcon https://www.summitracing.com/parts/dtl- ... gI9lfD_BwE :
But MAN have prices gone up!!
I hear the true trac is the way to go, don’t have to worry about the clutches wearing out. I wasn’t concerned about that when I got the tracloc, it’s just a cruiser, don’t plan on thrashing it toooo bad.
It's surprising where you might find what your looking for when it comes to rear gears.....my comet has a 8in LS unit from a 1976 V8 mustang 2,,,,I have had it in a 64 4spd stang,a,V8 63 falcon now in a 4sp 64 comet,,,,,,,so don't walk past anything,,always take the time to check out everything,,you never know where you might find just what your looking for,,,,,POP
Not discriminating between 8" & 9 ":
59.25 1967-1970 Mustang
59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
59.25 1967-1971 Comet, Cougar, Mustang, Fairlane
59.25, 61.25 1967-1973 Torino, Ranchero, Fairlane
59.25, 61.25 1967-1973 Mustang, Torino, Ranchero, Fairlane
1-2 inches is easy to accommodate with all the wheel offsets these days (or if you're not looking for widest tire - doesn't so much matter).
