brakes
rapdweasel
brakes
Post by rapdweasel »
if i wanted to switch my single brake master cylinder to a dual brake master cylinder. would one from an early mustang work. i dont want power brakes just a manual dual brake master cylinder. i thought one fro a 65 mustang would work with a mustang proportioning valve.
1962 Mercury Comet 302 with t5 5 spd also 5 lug conversion
It should work without a problem, make sure you have everything though back to the pedal, including the brake rod.
65 Mustangs also had single resevoir master cylinder. You need a 67-up dual resevoir master cylinder.
supercomet
Post by supercomet »
if you change your mind about the pb set up, a suzuki swift pb set up works great in these cars because it is small enough to clear everything and takes minor mods to fit it.
Drew Wanzer
"I love the smell of roasting tires in the morning"
