brake conversion
brake conversion
will a dual brake master cylinder conversion kit for a 1965 ford mustang work for a 62 comet. it comes from CJ pony parts. its the master cylinder, distribution block and the hard lines you need to go to the distribution block. or does any one else now a way to convert to dual master cylinder in a 2 mercury comet. thanks
1962 Mercury Comet 302 with t5 5 spd also 5 lug conversion
Master Cylinder
If your 62 has the two bolt flange and the pushrod is the right length,then it should work.If your pushrod is wrong I think those guys have an adjustable one. ROY.
