289 HI-PO heads
All that junk (I mean good stuff) on eBay
289 HI-PO heads
Postby 62Cometman » Tue Sep 11, 2018 8:29 am
i found a set of 289 Hi-Po heads decent price for the pair yes or no?
https://www.ebay.com/itm/Awesome-1966-F ... 0#viTabs_0
62Cometman
Re: 289 HI-PO heads
Postby Lip Ripper » Tue Sep 11, 2018 9:15 am
They are not hipo heads.
Lip Ripper
Re: 289 HI-PO heads
Postby bigdan » Tue Sep 11, 2018 9:31 am
True hi-po heads should have screw in rocker studs and cast in spring pockets. I've only laid eyes on one set, but from the research i did at the time other than those two items they're exactly the same as other 289 heads. If a fella is looking for a set of them I have an unmolested C5OE pair.
Dan
Currently diligently patiently trying to complete my 65 Futura long term project . . .
bigdan
Re: 289 HI-PO heads
Postby 62Cometman » Tue Sep 11, 2018 10:45 am
I was under the impression that only the Hipo heads got the 54.5cc chambers? Which the seller apparently measured. you are correct on the rocker studs though. Realistically im taking whatever set i buy to the machine shop to be reworked regardless but i want the 54.5 cc heads so i at least start with the same base as my 260 heads so im not take .060 or more off the head to try to get back to the 54.5 cc. If you have an extra set with the 54.5 cambers Dan i would be interested.
62Cometman
Re: 289 HI-PO heads
Postby bigdan » Tue Sep 11, 2018 12:35 pm
Ill look at them this evening. I want to say they're 57? cc heads, but can't see them from here LOL
Dan
bigdan
Re: 289 HI-PO heads
Postby 62Cometman » Fri Sep 14, 2018 7:43 am
Dan, did you ever end up looking at your heads?
62Cometman
Re: 289 HI-PO heads
Postby Rocket989 » Sat Sep 15, 2018 9:48 am
Almost all of the C3-C6 heads were 54cc nominal....meaning a cc or up/down is kind of to be expected. Things got murky in ‘67-‘68 with a few different head castings.
I wouldn’t worry about 2cc but if you want to be sure, you’ll have to CC them yourself. I wouldn’t pay more than $50 bucks for unknown condition C6 heads!!
Rocket989
Re: 289 HI-PO heads
Postby bigdan » Sun Sep 16, 2018 2:34 am
62Cometman wrote:Dan, did you ever end up looking at your heads?
Ran out to the shop and checked them out. They're C5AE heads, non hi-po. My references here state they're a 52-55 cc head.
Dan
bigdan
Return to eBay Finds
