This is basically a 4 speed complete kit.64 early 65 comet / falcon t10, old hurst shifter and rods that are super hard to find and expensive when you do. It needs the stick rechromed. Very nice 4 speed hump and ring, z bar , clutch ball, rods etc. bell housing , flywheel, clutch pedals etc. everything pictured $1200 . Local pick up in middle TN. Inside of the trans looks good, but assuming all could use a re freshing. Sold as is where is.
1964 early 65 Comet/Falcon 4 speed set up complete .
Re: 1964 early 65 Comet/Falcon 4 speed set up complete .
Would love to have it for my 65 Comet gasser build. Don't need the bellhousing or flywheel as mine is a 6 bolt block and zero balanced.
would you consider splitting it up. I understand if you won't. I am in east Tn.
- ArkansasComet
Is this still available? Thanks
