65 Caliente Inner Lower Door Panel Trim
If you need something, post it here
Postby kevinshi » Tue Jan 07, 2020 9:33 pm
Hey folks -
I am seeking a pair of the inside door panel lower trim pieces used on the 65 Caliente convertible. MPC tells me this same trim was used on the 65 2 Dr. Hardtop Calientes as well as the 65 Cyclone. The part number leads with C4GY so I suspect it also appeared on some of the 1964 models (I am quite sure one of you can tell me exactly where it appeared... ;-)).
If you happen to have a set of these in please let me know - this is the only trim part missing from my otherwise complete 65 that is now getting close to full restoration...
Thanks,
kevin
65 Caliente Convertible
5H25A525287
kevinshi
Re: 65 Caliente Inner Lower Door Panel Trim
Postby poboyjo65 » Tue Jan 07, 2020 10:10 pm
I think I have a set I'll look.
347, 4sp, 9''
Postby robertapy » Thu Feb 13, 2020 10:10 pm
i need the same if anyone has some extras?
robertapy
Return to Wanted
