WT280-12A (1st / REVERSE SLIDER GEAR)
79Bird
Post by 79Bird »
Hi All,
My brother is putting a 64' together and needs a gear for the "peanut box" 3 speed manual transmission. All new Scott Drake units are backordered for at least a month is what he is told by about 20 vendors. Hoping someone here might have one...
He's looking for:
Interchanges with C1DR-7100-A
For HED 3 speed manual 2.77
Let me know if you have one!!
1963-1/2 Mercury Comet Hardtop
1972 GMC Suburban 3/4T / 4 Speed / 4x4
1979 Pontiac Trans Am 400/4 Speed
1994 Ford Mustang 302 / 3550 / 70mm Turbo
caliente289
Re: WT280-12A (1st / REVERSE SLIDER GEAR)
Post by caliente289 »
I have a peanut out of 65 should be the same. I will check it.
79Bird
Post by 79Bird »
I was just about to update this. After scouring the internet for other vendors, he found a small shop that had 1 on the shelf and it's en route!!!
Now he needs to find a grille...the car came with no headlights or grille, he got the headlights but still needs a grille to wrap the front end up. Let me know if anyone has an extra.
