65 Headlight trim ring
fair67
Post by fair67 »
Would anyone have a couple headlight trim rings for a 65 Comet. Any help appreciated.
Thanks
Kingspeedy2
Re: 65 Headlight trim ring
Post by Kingspeedy2 »
pm sent
Kingspeedy2
I did a quick search for the trim rings online and found some for $6.18 each
Ar restoration parts source.com http://restorationpartssource.com/cgi-r ... e1f85c54e8
Try to cut and paste the link or search,lolls
Kingspeedy2 wrote:I did a quick search for the trim rings online and found some for $6.18 each
If the image on that link is what they have it wont fit a 65. the image has 3 tabs. 65 rings only have 2 tabs, one with a round hole for the spring, & a rectangular hole on the opposite side of the ring to hook on the headlight bucket tab. they are most likely a one year only ring.
caseville cyclone
Post by caseville cyclone »
Poboy is right on,my 1965 has 2 tabs and a hole for the spring along with a small spot weld that holds the ring together which will break very easily after age. I drilled a very small hole and the smallest pop rivet to put it back together. I can't remember if the uppers were different from the lower headlights. Maybe Poboy will know. Andy
caseville cyclone wrote:Poboy is right on,my 1965 has 2 tabs and a hole for the spring along with a small spot weld that holds the ring together which will break very easily after age. I drilled a very small hole and the smallest pop rivet to put it back together. I can't remember if the uppers were different from the lower headlights. Maybe Poboy will know. Andy
They're the same as bottoms Andy. & you are right they do break easy,as do the tabs on the buckets.& the buckets are different, all four are different, & have stamped markings to identify. be gentle with all of it,I dont think any are reproduced!!
fair67
Post by fair67 »
Thanks guys you are right there is only 2 tabs I couldnt find new ones anywhere I am going to try and JB weld the 2 together that I have noe. I did get a pm from a member who may have a couple.
Thanks guys
Kingspeedy2
Ok all, I let Fair67 down,my selection of extra headlamp rings I thought I had is no better than his so the hunt is still on for em!
65 cyclone 4 speed
Post by 65 cyclone 4 speed »
I have several of the headlight rings out of a 65 let me know what you need my cell is 660 287 1129 Thanks Kris
Here are some NOS ones, & according to the description fit a 66 fairlane as well as 65 comet. they look right for 65 comet. kinda high but probably not as brittle as a used one.
https://www.ebay.com/itm/NOS-1965-1966- ... oQ&vxp=mtr
seems like 67 fairlane should if 66 does? :?
Lip Ripper
Post by Lip Ripper »
Last year, when I saw what they were selling for I decided my extras are staying on the shelf.
fair67
Post by fair67 »
Thank you everyone I have managed to get the ones I have to work. I appreciate all the help and hopefully the JB weld will keep on holding.
Thanks
