Parts swapping at the Gathering
Activities Sponsored by Comet Forum Members
Ratical
Re: Parts swapping at the Gathering
Post by Ratical »
Groover, tag reads C5ZF C : C 5BB
Ratical wrote:Groover, tag reads C5ZF C : C 5BB
Groover that's 1.08" Venturi if the tag is correct to the carb.
All working and in good shape? Bring it along and let's make a deal. Now don't suppose you have a 4v intake laying around?
:shock: :shock: :shock: I shocked!!!!! Groover your steppin out of the box! :o
Well, as I'm reading up, it really would make more sense to build a different block (289). Adding a 4bbl to the 260 isn't going to give much more. It'll make good conversation around the tent though :)
mopar 346
Post by mopar 346 »
Groover wrote: Well, as I'm reading up, it really would make more sense to build a different block (289). Adding a 4bbl to the 260 isn't going to give much more. It'll make good conversation around the tent though :)
My thoughts as I was reading it but why stop at a 289, not real up on Ford small blocks but isn't a 351W physically the same externally? Do you have a C4 or the Ford-o-matic? 5 bolt or 6 bolt bellhousing, all things to consider. The * inch is plenty strong for most anything moderate you can throw at it from everything I've heard.
loman
Post by loman »
I believe the 351W is a bit wider and taller than the 260/289/302. Thats why intake manifolds and distributors won't interchange with a 289 or 302.
tntrash
Post by tntrash »
I could use a passenger side windshield wiper arm if any one is holding.
I have one. I think either side is the same. I'll throw it in the trunk.
Groover wrote:Well, as I'm reading up, it really would make more sense to build a different block (289). Adding a 4bbl to the 260 isn't going to give much more. It'll make good conversation around the tent though :)
There's a pic in the Mannel SBF book of a Ford tech installing a 3x2 intake and carb setup in a Fairlane 260! Cmon Groover it'll be ok! If you get the 4V setup stick a C9OZ hyd Hipo cam in there while your at it :twisted:
Groover -Cool new sigpic !!! :D I wish everybody had one, that way you know who said what - at a glance. I wish it was mandatory! :D
tntrash
Post by tntrash »
poboyjo65 wrote:I have one. I think either side is the same. I'll throw it in the trunk.
Cool deal! Thanks!
Groover this dont seem too bad with todays machine shop prices;
http://www.ebay.com/itm/1965-MERCURY-CO ... IB&vxp=mtr
You have more than one (original wiper), John?
I could use one too. My old original one works pretty good, but the MAC's replacement one doesn't hold the glass for $h!t.
But seriously, was there a 260 with a 4 bbl factory option? Perhaps a 63 Falcon Sprint? Pretty sure you didn't get 260 a 4 bbl in 1964.
