sputtering uphill
sputtering uphill
Postby captian_napalm » Sat Sep 17, 2016 12:32 am
I have a 170ci and when I am going uphill the car sputters like it is starving for fuel. Any ideas, thoughts?
captian_napalm
Re: sputtering uphill
Postby Lou's Comet » Sat Sep 17, 2016 6:03 am
Fuel filter, fuel pump?
Postby popscomet » Sat Sep 17, 2016 11:44 am
Lou's Comet wrote:Fuel filter, fuel pump?
trashy tank !!!plus the above.........[[..make sure it's timing is correct also]]...pop
Postby captian_napalm » Sat Sep 17, 2016 10:55 pm
tank was replaced by previous owner. timing looks good. I got the idle set on the carb. looks like its down to the filter and pump....thanks for the info.
captian_napalm
Postby captian_napalm » Sat Aug 05, 2017 7:32 pm
ok so I swapped out the points for an ignitor package.....new plugs, wires, had the carb rebuilt, but they screwed that up by loosing a part of the linkage......has a new tank from previous owner. just rechecked the timing after installing the ignitor ignition module. still hesitates on acceleration.....is it possible that the fuel pump is bad, or maybe the accelerator pump on the carb?
captian_napalm
Postby lavron » Sat Aug 05, 2017 8:44 pm
Remind me, what year Comet?
The old Load-O-Matic distributors (mid '64 back) were matched to the carb, if there is a mismatch between carb and the distributor will not advance properly, they were a vacuum only distributor, not sure of the fix (can't remember) but can try and look up the solution if there is one.
Postby captian_napalm » Sun Aug 06, 2017 12:00 am
lavron wrote:Remind me, what year Comet?
62 with a 170...not to sure if the carb is the org. it is the 1940 holley.
captian_napalm
