Gasket for heater spacer on carb 144 6
Postby KatKar60 » Sun Oct 22, 2017 7:51 pm
I have the carb to intake manifold gasket that mounts above the heater spacer but the one beneath it that sits directly on the manifold>I need that one. It looks more like a heat type gasket and is thicker. Where do I find one? This is for the 144 6 cylinder. Thanks.
KatKar60
Re: Gasket for heater spacer on carb 144 6
Postby lavron » Mon Oct 23, 2017 7:04 am
Postby KatKar60 » Mon Oct 23, 2017 11:35 am
Thanks, I'll give them a try!
KatKar60
Postby KatKar60 » Tue Oct 24, 2017 11:09 am
KatKar60
FYI Gasket for heater spacer on carb 144 6
Postby KatKar60 » Tue Oct 24, 2017 12:05 pm
Nope....wrong gasket. Called Fel-Pro. Gasket no longer available. You have to make your own using Fel-Pro number 2499.
KatKar60
