PCV connection to Maniford
Hello All, I'm now thinking of putting an actual PCV valve on my 144. It will require me finding a valve cover with the hole/grommet/baffle for the valve. My question--on sixes equipped with a valve, where does the hose enter the manifold? Is there a separate plate under the carb? On mine, there is a closed-off port on the intake that a fitting could also attach to. Thanks, Chris
