Solve my mystery, please
Postby Adams » Sun May 08, 2016 7:26 pm
Hello All, Hi Pops, Got my Comet back together with the 200 motor. Problems I had with the thermostat and pan are fixed. However, I'm having a horrible time to get it running correctly. Symptoms: hard starting unless spark is way advanced, hesitation, missing, lack of power when accelerating. It idles ok, although there's some missing. I've checked just about everything. Good carb, good fuel pressure, got spark, timed correctly, dizzy not in backwards. New ignition parts and wires. A real mystery. At this point, having checked so much, I'm wondering if it could be something else....for example, the motor had been rebuilt in the past, and had hydraulic lifters AND adjustable rockers. I rebuilt the head, and used non-adjustable rockers. I wonder if the head was milled so much that the non-adjustables aren't cutting it. Only one way to find that out, put the old rockers back on.
Adams
Re: Solve my mystery, please
Postby popscomet » Sun May 08, 2016 8:19 pm
Very possible the valves are to tight,,put your adjustables back on and give them a little slack and try that...if they are to tight it will cause most of what you experiencing
Postby Adams » Mon May 09, 2016 7:52 pm
Well, Pops, Today I replaced the supposed 'new' condenser that came with the rebuilt dist, and the hesitation and hard staring are gone! However, I still have a knocking sound, but only when accelerating. I disconnected the vac advance, and the sound ceased. I checked timing, and this great rebuilt dist seems to be advancing too far too fast. I've adjusted the dust springs as far as they will go, but I really need stronger springs. I'm still thinking if I put the adjustable rockers back on, I might be able to resolve the issue, as possibly a lifter/valve is eithe bottoming or opening too far, and when advance is put on, the effect is intensified. For the moment, it s driveable without advance, just won't win any races!
Adams
Postby popscomet » Mon May 09, 2016 9:00 pm
don't laugh !!!! take a stick and start the engine and put the stick against the fuel pump and the other end to your best ear and listen
Postby Adams » Tue May 10, 2016 5:55 am
Are you saying the noise could be from the fuel pump, or are you getting at something else? Sound is only during low load (high vacuum) acceleration.
Adams
Postby popscomet » Tue May 10, 2016 10:23 am
Adams wrote:Are you saying the noise could be from the fuel pump, or are you getting at something else? Sound is only during low load (high vacuum) acceleration.
yes sir,thats what I saying,the fuel pump
Postby popscomet » Tue May 10, 2016 1:07 pm
I'm throwing a few things to you that I have ran across in the past,and I have had fuel pumps that make a sound like dead lifters and bad whrist pins,had one once that sounded like a main was bumping,had a loose trq converter one time so it's very hard to pin point your problem not being there....I always try to help by putting the person in a direction to help him think,,and I'll always try to help!! you keep digging and POP will keep handing you the shovel........not saying your noise is a fuel pump,and the stick deal does work...also a rubber hose good luck be waiting to hear from you pop
Postby Adams » Tue May 10, 2016 1:26 pm
Thanks, I'll try it, and let you know what I find.
Adams
cron
