Carb linkage question
Postby H8D-62 » Mon Nov 07, 2016 8:06 pm
Hey guys just started working on my 62 comet. The little 1bbl autolite that was on it was thrashed. A friend of mine had one he gave to me, difference is it's a manual choke which is okay here in Ca. Barely need the choke anyways. Only hiccup I ran into is it looks like the accelerator linkage is different. Is there a different linkage I can put on where it all connects to the spacer under the carb or is the solution to just get a longer rod for between the carb linkage and accelerator linkage. Any help is appreciated. I've attached a picture to help show what I'm talking about.
H8D-62
Re: Carb linkage question
Postby popscomet » Mon Nov 07, 2016 8:17 pm
COOL,a pic is worth a 1000 words,right now with the carb not hooked up ,is the gas pedal in the correct postion??,,,,,I don't see why you can't rig up a longer linkage ,it won't be much longer,,just make sure the gas pedal sits correct,,not to high,not to low.....pop
Postby lavron » Mon Nov 07, 2016 10:23 pm
I switched between Holleys and Autolites and didn't have to change the linkage, will the long horizontal rod not adjust short enough on the end to pull the arm up higher?
Postby H8D-62 » Tue Nov 08, 2016 1:18 pm
lavron wrote:I switched between Holleys and Autolites and didn't have to change the linkage, will the long horizontal rod not adjust short enough on the end to pull the arm up higher?
I don't see any kind of an adjustment on the long horizontal rod. If that rod was shorter it could swing that bracket up and make it work.
H8D-62
Postby Comechero65 » Tue Nov 08, 2016 1:29 pm
Not as familiar with linkages on 6 cyl carbs but maybe this will help. It is listed for a 170/200 but also fits on v8 carb linkages.
https://www.npdlink.com/store/products/ ... 335-1.html
Comechero65
Postby lavron » Tue Nov 08, 2016 2:08 pm
H8D-62 wrote:I don't see any kind of an adjustment on the long horizontal rod. If that rod was shorter it could swing that bracket up and make it work.
Ok I have to admit I haven't had the stock linkage for years and mine is part of the OFFY triple setup and it has collars that slide on the shaft and lock down, I was trying to remember from years ago :roll:
Postby poboyjo65 » Tue Nov 08, 2016 2:59 pm
Can't you just cut it in the center & weld in a new piece of rod to make it longer?
347, 4sp, 9''
