inline 200
inline 200
Postby captian_napalm » Wed May 10, 2017 10:46 pm
I have a 65 inline 200, and the previous owner said it is burning oil.......ok needs rings right????? no.. it needs cylinder sleeves.....what the heck are these?
captian_napalm
Re: inline 200
Postby Lou's Comet » Thu May 11, 2017 7:08 am
captian_napalm wrote:I have a 65 inline 200, and the previous owner said it is burning oil.......ok needs rings right????? no.. it needs cylinder sleeves.....what the heck are these?
Cylinder sleeves are used to repair damaged cylinder bores. Some engines have them from factory. Don't know if the 200 had them from factory. Thought mostly diesel and industrial engines had them from factory so engine could be rebuilt without removing block.
But basically they are the bore
Re: inline 200
Postby lavron » Thu May 11, 2017 2:04 pm
Most likely rings, sleeves are to repair the cylinder usually, if you had one so worn or over bored (which is not likely) I would find a different block. Valve seals are bad about leaking as well, if that was the case it would smoke when it starts up and then clear up.
Re: inline 200
Postby captian_napalm » Thu May 11, 2017 5:53 pm
looking in Macs every other motor has rings available for purchase except the 200. All they show listed is rings.
captian_napalm
Re: inline 200
Postby lavron » Thu May 11, 2017 8:12 pm
you should be able to get rings anywhere (they are sometimes listed as 3.3L engines) like the local auto parts store, you might want to check and make sure it has not been bored out and has oversized pistons before you buy. Also check the bores and see how they look, if it is a pretty good engine a quick hone might be all it needs before putting the new rings on.
Re: inline 200
Postby captian_napalm » Thu May 11, 2017 10:36 pm
i believe its all original. the guy I got it from pulled it from his wife's mustang for a v-8....After all I have read about the 200, it is the better choice.
captian_napalm
Return to Small Six Performance
Users browsing this forum: No registered users and 2 guests
