Fuel bowl level
Posted: Thu Jun 22, 2017 10:28 pm
by Bluecollar comet
Hi comet fans
Rebuilding holly1909 1bbl carb. Does anyone know the specs. On fuel bowl level? How do i know if set correctly? Thanks !
Re: Fuel bowl level
Posted: Thu Jun 22, 2017 10:45 pm
by Jims65cyclone
See if this helps. It's for an AMC, but both AMC and Ford used the Holley 1909.
http://www.oldcarmanualproject.com/manu ... /H1909.pdf
Re: Fuel bowl level
Posted: Thu Jun 22, 2017 10:47 pm
If you bought a rebuild kit it should have ,,or most have some fine printed papers in it with specs for each engine that it is used on. or at least the bigger carb's kits have it.
Re: Fuel bowl level
Posted: Thu Jun 22, 2017 11:02 pm
poboyjo65 wrote:If you bought a rebuild kit it should have ,,or most have some fine printed papers in it with specs for each engine that it is used on. or at least the bigger carb's kits have it.
What John said and most I have used come with a cardboard gauge to help set it.
Re: Fuel bowl level
Posted: Fri Jun 23, 2017 10:48 am
by Bluecollar comet
I will look for that! Thanks much
