Fuel bowl level
Bluecollar comet
Fuel bowl level
Post by Bluecollar comet »
Hi comet fans
Rebuilding holly1909 1bbl carb. Does anyone know the specs. On fuel bowl level? How do i know if set correctly? Thanks !
Re: Fuel bowl level
See if this helps. It's for an AMC, but both AMC and Ford used the Holley 1909.
http://www.oldcarmanualproject.com/manu ... /H1909.pdf
Re: Fuel bowl level
If you bought a rebuild kit it should have ,,or most have some fine printed papers in it with specs for each engine that it is used on. or at least the bigger carb's kits have it.
Re: Fuel bowl level
poboyjo65 wrote:If you bought a rebuild kit it should have ,,or most have some fine printed papers in it with specs for each engine that it is used on. or at least the bigger carb's kits have it.
What John said and most I have used come with a cardboard gauge to help set it.
Bluecollar comet
Re: Fuel bowl level
I will look for that! Thanks much
